OEM VW Center Caps falling off (solved!)
GolfGTI2014
Charlotte, NC
When I purchased a set of Neuspeed RSE10 wheels, I was happy to be able to reuse the factory VW center caps. Unfortunately, after a track event, I found that the heat caused them to deform and they just fell out of the wheels. The Neuspeed wheels came with center caps that fit very well but I did not like the look of them. After a bit of looking around, I found 3dcarstickers.com. I was not sure what the result would be, in fact, I was not even sure that the site was legit. But, for $8.99 I thought I would give them a shot. I ordered the following:
VOLKSWAGEN 3d car stickers for wheel center caps СARBON LOOK (53 mm) (x1): USD 8.99
They just stick onto the RS center caps and seem to do the job.
I have attached a picture....
Baldilocks73
Delaware, U.S.A.
2015 Golf R
I used hot glue on mine to keep them in. :)
Genegenie
North Yorkshire
VW Golf
Think centre cap dia. for standard Golf wheels is 55mm, a good solution that looks cool. Or you could do as I did: wrap sellotape around centre cap to create a tighter fit, in my case around the plastic cap on security locking bolts....
