Obdeleven standard help
VWeGoBeachNow
OC - PCH - CA
MK7.5 DIBM AB 6sp MT
Hi there,
I'm new to this forum and this is my first post. I tried plugging the obdeleven standard dongle I got off Amazon into my 2020 GTI obd2 port but it doesn't want to go in. Shouldn't it just go in without a problem or am I doing something wrong?
Much Thanks!
Keehs360
Denver
Mk7.5
Make sure it's not backwards. But I'd just get on the ground on the driver's side and visually make sure it's going in the right way. There's like this notch. Make sure it's sliding in correctly
VWeGoBeachNow
OC - PCH - CA
Hey Thanks for the quick reply! Yes I did get on the ground (ouch) and but for the life of me it would not go in and I didn't want to force it in. I've attached a photo of my obd2 port.
Keehs360
Denver
Mk7.5
Ok see the notch on the front in your pic? Make sure it lines up with the notch on the obd11. U have to push in gently. But if your obd port has never been mated it could take a small bit of force. Go low and slow.
VWeGoBeachNow
OC - PCH - CA
This obd2 port from a 2017 looks different than mine right?
https://www.golfmk7.com/forums/index.php?threads/obd-plug-help-needed.357674/
SnailpowerMk7
NJ
MK7 GTI SE 6SPD MT
It does require some pressure to get it in but I hate to tell you to use more force and end up forcing it when it just can't fit correctly for some reason causing something to break...
VWeGoBeachNow
OC - PCH - CA
it looks like the purple cover on yours has little "ears" that stick out the sides. I don't recall those on mine. is that what is keeping the dongle from being plugged in?
Hi there,
Yes. I have returned the obeleven already to I can't take a picture but it was brand new, nothing bent or anything. It looked exactly like this. Those ear things are in the way.
up4speed
Long Island
2015 GTI
I have never seen an OBD2 with those ears, it's just a tapered jack so it fits one way. Strange....
