Diggs24
- de plains! de plains!
- 2015 GTI
Cant imagine geometry and placement are the same as stock housing. What happens if you run the upper and lower stops?
So I set the charge pressure acknowledgment to 3.5 and it must have loosened up through some heat cycles of the turbine housing. Honestly I couldn't get it much tighter than that cause it started to get really hard to turnadjust til lower stop hits 3.5
Its a mahle is38What actuator? is20? is38?
Who tuned it?I just installed a tpc20 and I’m having the same codes come up. P256300 and p00af00. Will be doing some testing tomorrow will come back and let you know my findings.
Definitely lemme know what you found. Im gonna do some digging on my setup as well and see what I findI just installed a tpc20 and I’m having the same codes come up. P256300 and p00af00. Will be doing some testing tomorrow will come back and let you know my findings.
Nobody, this was upon the first start up. All I had to do was adjust the actuator to the correct voltage. Did it with obd11.Who tuned it?
