OBD11 wastegate adaptation
MonkeyMD
I had to turn car off and on a few times till it worked. Is been a while so can't remember exact details.
Gvazquez
North Carolina
Cant imagine geometry and placement are the same as stock housing. What happens if you run the upper and lower stops?
This is all the obdeleven info I have that would probably help. Im having underboost codes and epc light
Gvazquez
North Carolina
It still runs oem style housings but they're much larger. I didnt think that would affect the voltage ranges?
Gvazquez
North Carolina
adjust til lower stop hits 3.5
So I set the charge pressure acknowledgment to 3.5 and it must have loosened up through some heat cycles of the turbine housing. Honestly I couldn't get it much tighter than that cause it started to get really hard to turn
Gvazquez
North Carolina
Kyle1116
Miami
I just installed a tpc20 and I’m having the same codes come up. P256300 and p00af00. Will be doing some testing tomorrow will come back and let you know my findings.
Gvazquez
North Carolina
Definitely lemme know what you found. Im gonna do some digging on my setup as well and see what I find
Mini7
Charlotte, NC
2017 GTi Sport PP
Checking my Wastegate calibration on OBD11
Charge pressure actuator acknowledgment is the parameter to check. Correct?
Daily Driver
New York
2020 GTI SE
Did the wastage Adapter process change on OBD11?
I can't find Charge Pressure Acknowledgement in live date anymore.
But there is Charge Air Pressure Control valve uncond voltage sensor.
I'm guessing I would adjust here in Live Date.
Then proceed to basic settings for first adaptation charge pressure actuator.
Has anyone done it recently? What this the process?
