OBD11 wastegate adaptation
1jzlive
Florida
Does anyone kniw how to set wastegate adaptation with obdeleven as in the steps ,
Thank you ahead of time as i dont have vcds ajd have been told obdeleven is possible
Hoon
Rhode Island
Live Data - Acknowledgement of charge pressure actuator.
Set your voltage
Basic settings - First Adaptation of Charge Pressure Actuator.
Contrary to logic, it is not under Adaptation.
Diggs24
de plains! de plains!
2015 GTI
Good luck.
1jzlive
Florida
Set your voltage
Lol i figured out ,when u said contrary to logic that wqs hilarious thanks broksi you too diggs
kornsined
Alberta
Set your voltage
If you pass does it just go green and say “basic settings ended”?
Peylix
Everett
I'm trying to do this, but it errors out on me.
Sorry for the necro post btw. But this is the only thread I could find regarding OBDEleven & wastegate adaptations.
Peylix
Everett
I had an IS38 installed and the wastegate needed to be adjusted properly. It was reading 4.5v and was giving me the P256300 error & EPC light. So I adjusted the voltage down to 3.5v and now need to re adapt the wastegate.
This is the error OBDeleven gives when I try to do the adaptation via "Basic Settings" as listed above. (13) function cannot be performed, mess, length or format incorrect
The one error that plagues a bunch of folks withing numerous parts of the app. That's never been resolved.
MonkeyMD
Just disconnect from obd11, close app, reconnect and try again.
Peylix
Everett
Doesn't work. I even cleared cache & data, and even uninstalled & re installed the app. Unplugged the device, plugged back in, the works. Spent over 8 hours trying to get OBDeleven to run the adaptation but it always resulted with Error 13.
I got an email this morning from OBDeleven themselves stating that they are aware of the issue and have been trying to fix it.
Gvazquez
North Carolina
Feel like such a noob bringing this one back but any clue why when I try to run adaptation the test doesn't run and it fails? To my understanding it only fails because its either too loose or too tight. Im set at 3.5V and it still fails to run the first adaptation of charge pressure actuator
Gvazquez
North Carolina
