OBD11: DRL Pulse V2
Just tried the app to activate DRL Pulse V2, it works fine for a few seconds but then it completely turns off the DRL on the right headlight,
Video of the issue:
ufile.io/btraobhr
I reverted it back to original setting, but would love to have this in function in working order..
Any help will be appreciated. TIA
Sent from my ONEPLUS A6003 using Tapatalk
Looks like there may be an issue with the headlight itself as the inner u cuts off before the outer U. Coded mine a few years ago and still no issues with it. Old school when something like that happens it used to be a bad earth so maybe worth checking the connector plugs pins are not corroded inside.
I doubt that since reverting back to OE code, they work as normal!!
vwlotech
Lexington, KY
Video of the issue:
ufile.io/btraobhr
Is there a V1 of this OBD11 App? also intrested in the long code if out there
