Sportwagen SEL
- Burlingame, CA
Thought I would share that I finally figured out how to adjust the brightness of the blind spot indicator via VCDS! Go to 09 central electronics --> adaptations --> turn signal control --> Warnblinktastersuchbeleuchtung Grundwert. Here you'll see a percentage value controlling the intensity of the LED. Stock value is 10 with a valid range from 0-127. You're welcome! ?
