NYS new inspection requirement for 2023?
chuncomunco
NY
Saw this on the F30 forums:
"Confirmed - next year any car in ny with a tune, regardless of readiness monitor status, will fail ny inspection. Also we will be required to do a 360* walk around the car with an inspection camera, and the catalytic converter must also be photographed for the inspection."
Post link.
Not sure how true it is, just wondering if anyone here heard about this.
SnailPower
North NJ
2017 GTI MT, PP, LP
Post link.
Some areas in Jersey already do this. At least the visual inspection to match up OEM spec against whatever they see under your car with the camera. I'm not sure how any car in ny with a tune would be an issue. How can a Stage1 tune that technically doesn't alter anything hardware wise be an issue? It actually makes the car more efficient. I can see Stg2+ being issues because of course, at that point you're modifying hardware.
StorableComa
SoCal, USA
17 GSW S FWD
They do this in California and I think in Colorado too. They scan your ECU and check your Calibration ID and Calibration Number vs What it should be stock. If you have any other software flashed, it'll return a different checksum and fail you.
Only non OEM checksums allowed here are CARB approved tunes, which is Cobb stage 1 and APR, There is another company I believe but those are the two big ones. Note that's Cobbs included stage 1 tune that came on the AP, not a tune from another company using the AP.
crxgator
Raleigh, NC
All the MQBs
At this point register it in Montana. If I ever have to move back to NY that’s the plan.
j255c
New York
2018 Golf R Manual
