not-FS Cobb AP3-VLK-002 DSG unlocked, learn from my mistake
BlackDog68
Metro Boston, Massachusetts
16 GTI autobahn dsg
Hi,
Selling my Cobb AP, various EQT stage 1 maps and DSG tune.
$450 shipped
  • Like
Reactions: Jod
BlackDog68
16 GTI autobahn dsg
Is there a specific DSG box code? Would this work on a dq 250?
More info:
AP3-VLK-002 v1.7.4.2-24013
Vehicle Name: USDM Volkswagen CCF Mk7 GTI / Audi A3 (CXCA 5G09C0BB01)
Vehicle ID: VLK_CXCA_5G09C0BB01 (Installed)
Transmission ID: VLK_DSG_0D9300020J (Not installed)
Serial: VLK0203119
Upgrade Serial: 00000 Original Serial: 62a00c2f
ECU Reflash map: EQT - Stage 1 93 v2.01 - LC TC
Transmission reflash map: (Uninstalled)
BlackDog68
16 GTI autobahn dsg
More info:
Serial: VLK0203119
My research tells me my mk7 gti would have had a dq250
aaronc7
17 S3
yeah the GTI dsg box codes tend to vary my year, his is 20J which is commonly 16 and 17. 15 is usually 41T. 18 I'm not 100% sure, so yeah I would double check.
Also, according to the more info posted above, it's still installed to the ECU. Not sure if that's current or if that info was pulled before completely uninstalled. Not trying to insult anyone's intelligence or anything-- when I bought mine used, the guy accidently only uninstalled it from the TCU before sending out to me. Easiest way to tell is there will only be like 3 icons on the main menu, if completely uninstalled.
BlackDog68
16 GTI autobahn dsg
Hmm, I'm not offended, if I failed the uninstall I'd like to know, how exactly do I see this? Unfortunately, I no longer have the car.
aaronc7
17 S3
You pulled that from AP manager, if you didn't connect AP post uninstall the. I guess it would have no way of knowing.
Power up the AP with USB cable, you can tell from the main screen icons. Should only see install, diagnostic and maybe 1 other. If you dig into the settings it will say too.
BlackDog68
16 GTI autobahn dsg
Well, lesson learned the hard way, it seems I only uninstalled the TCU (DSG) and not the ECU. So this thread is now at an end. I talked to Cobb and they want $507.50 to "re-license" the AP. I should have payed mor attention to the uninstall videos, doh!
