Non vent gauge pod solution!
nype
Vancouver, B.C.
I already had a line connected from the tap in my FMIC, so I reused it. Standard 3mm silicone vacuum tubing .... worked perfectly
Thanks. I wonder if this 4mm tubing would be too thick then. Just needs to fit snug into the rubber couplers on each end I guess.
impulsive.ca
What's used to hold the mount down to the column? Looks like it doesn't fit very well and sticks up in places? Maybe it's just in the pics, but that would drive me nuts.
swcrow
right now, nothing but the friction of the back end fitting in between the steering column and the dash. Pretty good fit, but does have some side to side movement which I’ll fix with 3m tape
impulsive.ca
I haven't checked to see if this would be possible, but a complete replacement piece for the top of the column would be way better. Obviously it'd be more expensive. But it sure would look better.
nype
Vancouver, B.C.
Agree. I’d gladly pay for better fitment. Guess any similar shaped pod could be mounted in that spot though.
swcrow
Well...this is a mk6 part as the OP stated.
A total replacement would definitely be more expensive and this piece only needs a tad of securing, otherwise is great
