I just did my first track day of the year this weekend at Gingerman, it was a blast! I decided to use what remained of my Hawk HPS pads in the front, and fresh OEM rear pads. I installed the RS3 brake cooling ducts and had a fresh bleed with RBF600 as well.
Being that this was my 2nd HPDE ever and my first at this track, I had an instructor and I was in the novice group. The first half of Saturday was a lot of instructional laps and being stuck in traffic. Eventually in the afternoon the traffic thinned out and I was able to push for a few laps. I had one full session without much traffic and during that session my front pads went from about 2 backing plate thicknesses to 1 backing plate thickness with an insane amount of pad transfer on the rotors. The rear pads and rotors looked fine, with no crazy pad transfer or wear. The instructor verified that I was not doing anything incorrect on the brakes. The brakes didn't feel bad despite the large amounts of pad transfer and I never felt any large amounts of fluid fade either. I was able to run a 1:51.9 which I was pretty content with given my car and experience.
Day two I tried to take it easy on the brakes. Most laps I would take the corners at regular speed but then stop accelerating around 80mph on the straights so I didn't have to brake as long for the next corner. I would still do one or two full speed laps per session, but give the car plenty of cooldown between them. Also, I was able to find a fellow GTI driver who had an OBD11 and I used that to turn off my XDS completely. Before I turned it off, I could feel it activating the inside brakes around a lot of the track, so I figured it was definitely causing some of my brake wear and heat. Overall, limiting my speed on the straights and deactivating XDS meant I had enough brakes to get home at the end of the day (I had some autozone pads as a last resort too). I still had tons of fun, but obviously I would've liked to have more confidence in my brakes on the second day.
I was expecting the car to understeer off every corner without XDS but it was actually not bad. If you get on the power aggressively with too much steering, it would definitely push more than with XDS on, but I learned more throttle and steering control with it off. I wasn't much slower with it off either.
So, now that I have proven that I can not use Hawk HPS pads on track on my front brakes, I'll be looking for some decent pads, performance pack take off brakes, or a big brake kit. Is anyone running the Ferodo DS2500's on the front of a non-pp for track days? I've heard it's a decent choice and FCP Euro has them for the front of non-pp cars. Also, how big of a difference do slotted rotors make? I think my car is about due for new rotors anyway if I stick with stock brake dimensions.
Finally, a few times on track I had a strange thing happen with my brakes and I'm curious if anyone else has experienced it. At the end of a straight, I would go to the brake and it would almost immediately feel like ABS had kicked in, the pedal would vibrate like it does with ABS. While this was happening the pedal would also go soft and I would ease off the brake a bit. As I eased off the brake, the ABS feeling would stop and the pedal pressure would all immediately come back (while my foot was still on the brake) and I could push hard again with normal feeling brakes. It was like I had brake fade that was only present during ABS during the first part of a braking zone but it was happening when it didn't feel like ABS should've been doing anything. Could it have been pad knockback? Has anyone felt anything like that? Again, I'm new to HPDE's so it could've been something I was doing wrong, but it definitely felt weird.
Edit: It looks like up4speed is running DS2500's on his non-pp car, I forgot that was mentioned earlier in this thread!
