I went with Ed's, and have no regrets.
BE SURE TO TEST THEM BEFORE PUTTING EVERYTHING BACK TOGETHER. I had the spade connectors backwards, and if I had buttoned everything up it would've been quite annoying to pull it all back apart again.
Also, be aware that if you're in the states, these don't have the amber reflector in the housing, which the dealer may not let slide for inspection. However, third-party shops may not notice or may let it slide.
I also had the halogen lights, PO installed LED bulbs but the light output was still subpar. Upgrading to Ed's was a massive improvement, and I can't recommend them enough. Resources online for instruction were great, though be aware that the instructions for the HID kit will not be clear on the spade connector positions -- I want to say it's blue to blue, black to white, but again test before you put everything back together. If they're not correct, you won't damage anything, but your lights won't work.
Support from Ed was fantastic throughout the whole process, and they're worth every penny IMO.
https://www.becautoparts.com/
