Already done some VCDS tweaks:
Heated Seat Memory
Heated seats will resume last setting upon re-entering the vehicle.
Select Control Unit 08 – HVAC
Adaptation
Change “Retention of the seat heater level driver” to active
Change “Retention of the seat heater level passenger” to active
ESP Option in Car Settings
Show the Electronic Stability Program setting within the car menu on the headunit.
Select Control unit 03
Control unit long coding
Byte 29
New Value 09
Auto Close Windows When Raining
When rain is detected on the rain sensor, the windows will automatically close.
Select Control unit 09 (Central Electrics)
Security access
Access code 31347
Adaptation
(15) Access Control 2-Regenschliessen_ein_aus
Value: Permanent
(16) Access Control 2-Regenschliessen_art
Value: Permanent
(28) Zugriffskontrolle 2-Menuesteuerung Regenschliessen
Value:Aktif
Control unit Long Coding
Subsystem: Rain / Light Sensor (RLS)
Byte 0
Bit 1-Bit 2 DeActivate
Fan Speed Display on Auto Mode
Show the A/C fan speed when operating in auto mode.
Select Control unit 08 (Air condition A/C)
Byte 11
Bit 6 Activate
DRL Control on Car Menu
Enables a setting on your headunit which allows you to completely disable the Daytime Running Lights.
Security access
Access Code 31347
Adaptation
(2) Daytime running light activation by BAP or Operating sequence possible
Value = Aktif
