New in box: hub rings for VW & Audi. 57.1mm ID, 66.6mm OD (shipping available)
GoatAutomotive
Georgetown, TX
2017 VW GTI SE, DSG
WHAT IS IT:
Complete set of 4 brand new, never installed hub rings for VW & Audi.
Specs: 57.1mm ID (hub bore), 66.6mm OD (wheel bore)
WHAT DOES IT DO?
Allows you to safely run an aftermarket wheel with a 66.56 to 66.6mm hub bore, safely, without causing stress to the OE wheel bolts, and without dealing with unwanted vibrations. i.e. Konig wheels and many others.
FITMENT: Most 2005+ Audi and VWs are 57.1mm hub bore. DM me if you aren't sure. I will also need the specs/model # of the aftermarket wheels you’re considering.
This will confirm if you're looking at the right hub rings here.
SELLING BECAUSE... I needed aluminum: these are polycarbonate. Great for street use, and they'll never rust or fuse to your hubs...just not cut out for track days due to the 500-900* F heat we generate in our braking systems on track.
PRICE: $20 picked up locally in Round Rock, TX (5-min north of IKEA)
Shipping available for $5 if needed (USPS)
PAYMENT: Cash or VenMo.
Fastest way to reach me: "supershepsky" at gmail-dot-com is my email. I don't make it onto this board like I used to, so DMs will have extended delays.
Thanks for looking!
