Go do your homework boyIt's because the 2019 GTI uses a different turbo inlet.
What oil where you using?Stage 1 powermax
Rotella full synthetic 5W40What oil where you using?
It was posted in the EQT group and it happened to a couple of people from Australia and this was the reasoning Garrett gave them according to the poster.You're the only person I've seen suggest this.
And the reason 2019 GTIs are spec'd to use 0w20 is because the emissions requirements for the GTI are a bit stricter (See APR turdo megathread). Just run a 30 weight if that's actually a problem. For whatever reason, Garrett only listed up to 2018 on their compatibility list and that spawned a litany of conspiracy theories as to why you shouldn't use these turbos on a 2019+.
For instance, IE has this nonsense on their page for it:
This just.. isn't true? And the Garretts come with their own actuator anyway.
Look what it says under my handle, and then see what it says under your handle, boy. Maybe then you'll understand when someone is kidding. Boy.Go do your homework boy
The guy who was posting a video of his "friend's" car? If that was even real it's more likely he just overspun it. Just like this guy probably did.It was posted in the EQT group and it happened to a couple of people from Australia and this was the reasoning Garrett gave them according to the poster.
Do you have more information about the tune and the boost you where running?Who tuned your car?
I think ITGUY is eqt tuned.Do you have more information about the tune and the boost you where running?
But answer the key questions please, tune and boost?I'm not EQT tuned.. I have yet to pull the charger pipes off or dropped the oil pan.. I'm waiting to hear about the warranty. I think the motor is ok.. I didn't hear anything odd when it happened. when I slowed down it just stalled.
All good, I have trouble detecting irony/jokes at the forum, will crawl back to by hole, LOLLook what it says under my handle, and then see what it says under your handle, boy. Maybe then you'll understand when someone is kidding. Boy.
