New EQT 5BAR tMAP Sensor!
Ed @ EQT
GOLFMK7 Official Sponsor
Fairfield, CA
MK8 Golf R
We have an exciting new product for the VAG MQB platform! This has been in the works for almost two years and we finally have our final production units in stock and ready to ship!
Introducing the EQT 5BAR TMAP Sensor! This is an OEM style, true direct fit tMAP sensor that reads up to 5 Bar absolute pressure. This sensor installs into the intake manifold just like the factory sensor and accepts the factory connector. No more boost taps, vacuum lines, zip ties, adapter harnesses, and filed down diesel sensors! Just pull the connector and one bolt, swap in your new EQT sensor, and you're ready to run up to 58psi (relative manifold pressure at sea level).
Here are some key features:
- 100% Direct plug and play fitment for OEM manifold and connector. (Cleaner engine bay, fewer points of failure, easily reversible, better response)
- Less expensive than currently available solutions
- 5 BAR Absolute Pressure maximum range (58psi relative boost at sea level)
- OEM quality temperature compensated circuitry
- Intake Temperature signal matched to factory sensor (no special calibration necessary)
- MAP signal calibration matched to popular 5 BAR sensors. (No tuning modification necessary when switching from AEM 5 bar)
- Complete calibration data provided.
** Tuning is required to run this and any other upgraded MAP sensor **
Now available for purchase for $195!
EQT 5 Bar TMAP Sensor – Equilibrium Tuning, Inc. (eqtuning.com)
