New Eibach Pro Kit Installed
MK7Fanatic
Canada
Mk7.5 GTI
When they do sag...its typically the springs settling into things like the rubber isolators.
It's like cable stretch on a bike. Its not the cable stretching but its the cable housing settling into the ferrules
Good point. I'm not expecting to go down any more i think its already low enough as it sits imo.
Really enjoying the car now though! Can't stop looking at it lol
EricsVdub
Chicago 'burbs
2019 GTI SE Exp pkg
Not true
The front is trickier, but you can jack the car up and slide the dust boot up & the bump stop down and then trim/cut it with a sharp razor blade. Just made sure you don't cut into the strut shaft. There's just limited space there with the spring's coils possibly getting in the way.
The rear is definitely easier and can be done on the car still though. Jack the car up, cut the zip tie for the shock's dust boot, slide it down & out of the way. Then pull the bump stop down and trim/cut the end off while not cutting into the shock's shaft. Slide the bump stop back up into the shock mount, zip tie the dust boot back up and you're done.
I've cut the front bump stops on the car with a really sharp steak knife, when the wife wasn't lookin'. Not a perfect cut but good enough.
Hmm, and people on the forum criticize the 2x4 method for strut removal/installation as being unsafe? It may be possible for some using that method, but I suspect not most. I'm pretty sure my hands wouldn't fit between the coils to do that. I recall having to remove the rear fender liner to get to the top of the shocks. If so, once you get that far, why not just remove the shock? Much easier to make a good precise cut with the bump stops removed IMHO.
odessa.filez
Roswell, GA
2016 GSW 1.8tsi auto
it can depend on what springs you're running, I suppose. Coilover springs on struts with a lot of coils would be difficult, oem style is more feasible.
Rear shocks are easy enough to remove and no springs involved, so removing the shock might be a better.approach.
edit, btw I highly recommend these, 'if you have the means'
https://www.williams-sonoma.com/products/wusthof-classic-4-piece-steak-knife-set/
pretty good on steaks too
snobrdrdan
former GTI owner
Hey I didn't say the front was easy....I said it could be doable but also tricky depending on the springs. Depends on how good you are at removing the struts too versus it being worth it doing it that way or not.
And there's nothing "unsafe" about cutting them on the car, lol.
The rears...I literally just cut the bump stops with mine on the car, so I'm going from experience. You DEFINITELY don't have to go thru the trouble of removing them.
Cutting a zip tie (for the dust boot) is waaaay easier than going thru the work of removing the fender liner, getting to the shock bolts & disassembling the shock. It's not hard to remove the shock, but unnecessary IMO
Pics for clicks...cut the zip tie & drop the boot:
4F8CCD9B-550E-4DB4-885B-E31527ED8D9B by snobrdrdan, on Flickr
Lowered the bump stop:
CF3D6B46-35C4-40B5-9270-DF852F819540 by snobrdrdan, on Flickr
I took a Dremel & cut the white plastic ring off first. Then took a SHARP razor blade and cut the bump stop as I rotated it. Then cut a slit to remove it off the shock:
5CFD78AC-749B-41B9-877D-C95EAF45258E by snobrdrdan, on Flickr
Final result:
FB16C9A4-3EF3-4AC9-A216-E89E9563BC58 by snobrdrdan, on Flickr
Slid the dust boot back up and then zip tied it to the shock mount, like it was.
Keehs360
Denver
Mk7.5
EricsVdub
Chicago 'burbs
2019 GTI SE Exp pkg
Final result:
Props on that precise of a cut with the rear bump stops on the shocks! I would've expected a much messier cut via that method. I don't recall them being the easiest thing to cut through precisely even with them off the struts/shocks. Did you trim the fender liner to access the shocks that high up? I'll have to look at mine again, but I recall them covering more of the top portion of the shock than that? By unsafe, I just meant the possibility of cutting a finger as opposed to the bump stop, especially using a steak knife LOL.
BTW, I still need my fingers to count to ten, so can't afford to lose one, YMMV.
MK7Fanatic
Canada
Mk7.5 GTI
Final result:
Nice work! Good to know it can be done without removing the whole assembly, Definitely do not plan on doing that.
So far so good though no bottoming out
SnailPower
North NJ
2017 GTI MT, PP, LP
Hey! After going back and forth on which springs to get (H&R OE, EMD, Eibach pro kit) I settled on the Pro kit. Super happy with the outcome, no signs of reverse rake and and the drop looks perfect. They still have to settle
Took me a good 6-7 hours to install w/ 2x4 method
Awesome. Is your car DSG or manual? Wondering if you do not have reverse rake because DSG? My buddy at work has Eibach (not sure if Pro kit) and he doesn't have reverse rake. I just cancelled my EMD because of backorder until August. Wondering if I should go with H&R or look into Eibach... Manual here so reverse rake miiiiiight be a concern.
Clem604
Vancouver BC, Canada
2018 VW GTI
Yes the DSG models don't have reverse rake like the manual does. This is true for for the VW Driver Gear springs I am running. If you are worried about rake just pick up a set of Audi TT rear spring pads and you'll be good to go.
SnailPower
North NJ
2017 GTI MT, PP, LP
I ordered the pro kit but decided to change it to sportline kit. I think I want a more noticeable drop than what I saw in your pics. Something where the upper wheel is slightly tucked into the fender. SLIGHTLY. I really want to see zero gap.
odessa.filez
Roswell, GA
just get bigger tires
SnailPower
North NJ
2017 GTI MT, PP, LP
It's cool. I'll rock it for hopefully a couple years and if I get tired of it, I'll sell them off and go a lil higher.
MK7Fanatic
Canada
Mk7.5 GTI
Mine is DSG no reverse rake what soever. If anything the rear sits about .5 finger gap higher which i really like. I was going to go EMD as well but back ordered and worried about the drop being too low. The pro kit is actually lower than i anticipated but it does look great. It's a very noticeable drop from stock height
Curious to see how yours turns out please let us all know. I can't picture myself going any lower. Really want a minimal but noticeable drop without having to worry too much about road conditions. Even with the pro kit definitely have to watch for rougher roads.
After more driving on all sorts of road the ride is noticeably stiffer on rougher roads and bigger dips/ potholes. Smooth and semi-smooth roads feel amazing.
Here it is after about a week after install and 100 miles later. Front is 1 finger gap and rear about 1.5
