Adapting setting :
Adapt the air flow direction (from air vent)
press AC button 8 and button 3 , the indicate light will blinking ,if the setting is done , the indicate light will illumination as normal .
Adaptor air compressor
Press button 8 and 16 for a few seconds , the indicate light will illumination . and the setting is done .
If the compressor running in first time , press button 8 and 16 for five seconds . the indicate light will illumination at same time, the adapting setting is done . air condition AC can work as normal .
This time the indicate light will not blinking , you need press 30 seconds ,then switch off by “off” button , and switch on AC to check if the compressor is working . if the setting is not working , please try more time for operation of adaptor air compressor
1 use keys to open fire And hold the third button ‘3 ’above and AC key‘ 8 ’more than ten seconds, until the air conditioning automatically stop,
2 at the same time Hold down the after the wind hot keys ‘16 ’and of AC key‘ 8’, more than ten seconds, until the air conditioning automatically stops
Until the air conditioning automatically stop.According to the above two steps air conditioning reset is complete, function normal.
