New APR Intake System for Only $189.95!
Arin@APR
GOLFMK7 Official Sponsor
Auburn, Al
B8 S4, MK7 GSW TDI
The APR Open PEX Intake System is Here!
http://goapr.io/mqbpex
The APR Open PEX Intake System is the best dollar-per-horsepower intake system for the 1.8T/2.0T Engine! We’ve maximized performance and sound dramatically by reducing pressure drop and increasing airflow. This translates to more horsepower and torque, and less physical strain on the turbocharger. The system looks great, sounds amazing, and produces more horsepower and torque you can feel.
Quick Info
  • More horsepower with gains up to +12 AWHP over stock
  • More torque with gains of up to +13 AWFT-LBS over stock
  • Greatly outflows the full factory frontal airbox by 60% at 833 CFM vs 521 CFM
  • High heat deflection PEX construction
  • Massive 7” washable and reusable cotton filter with a frontal inlet and 4” rear outlet
  • Creates an intoxicating intake sound in the engine bay
  • Improves throttle response
  • Lessens pressure drop
  • Lessens strain on the turbocharger
  • Lessens heat retention compared to other materials, such as metal
  • Compatible with APR and factory rear intake tubes and turbo inlet pipes
  • Easily installs in minutes
Our Open PEX Intake System does away with the closed airbox design and uses a massive 7” washable and reusable cotton filter with a frontal inlet and 4” rear outlet. This was necessary to limit pressure drop across the factory system and maximize airflow, while allowing you to fully hear the engine breathe! The massive filter provides excellent filtration. By oversizing the filter, we’re able to limit pressure drop without sacrificing filtration. This is made possible through the use of greatly increased filter surface area. The PEX material give the intake an Oem feel and it allows us to make a complex and organic heat shield shape that keeps hot air pushed through the frontal radiator away from the intake tract. Lastly, PEX retains heat less than other materials, such as metal, making it ideal for performance.
Overview, Sound, and Install Video
Flow Bench
The factory intake system simply can’t match the performance of our intake system. The full factory frontal airbox only flows 521 CFM at 28” of H2O. We improved this by 60% with our open airbox, which flows 833 CFM by comparison! However, it’s important to always look at the intake system as a whole as flow numbers alone don’t always speak to the broader picture. The factory turbocharger can only flow just under 400 CFM through the factory opening, and any intake system will lessen maximum flow. The goal is to minimize all restrictions before the turbocharger as much as possible to maximize performance. The full factory system brings this down to 275 CFM, or 31% less. The full APR System (Open airbox, rear pipe, and turbo inlet pipe), bring this down to 345 CFM, which is only 13% less, or a 25% improvement over stock! This directly translates to more power you can feel. Our full bolt on APR Tuned S3 saw max gains of 12 AWHP and 13 AWFT-LBS of torque using the full intake system compared to stock! These are solid gains that make a noticeable difference in performance!
Photos
Get the details
R Golf
Lenox, MA
Looks/sounds like its worth investigating. Fair price as well. Are these HP gains applicable to an already APR Stage 1 tuned car or will the tune simply reach its HP targets easier?
R Golf
Lenox, MA
Typically the more you mod the car, the better the results get.
Maybe sometimes that's true., but my original question remains. Since it is APR tune/APR intake I thought you might have info on it.
My car has an APR Stage 1. Do you know if I can expect hp/torque gains with this and if so, about how much? APR shows 12hp and 13 tq over stock, which is excellent bang for the buck in my opinion. Any idea what I could expect over a Stage 1, if anything?
It will be a negligible increase. You'll notice much more sound mostly.
GTI_Owner
2016 GTI
Since it is stated as "max gains of 12 AWHP and 13 AWFT-LBS of torque" and no dyno chart is shown, it could be a very narrow range of engine speed where that maximum gain is achieved, and everywhere else it could be much less.
Arin@APR
Auburn, Al
B8 S4, MK7 GSW TDI
The gains we saw are mostly towards redline where you begin to get a greater pressure drop on the stock intake system. You'll see similar gains to the gains mentioned on the site. This is especially true on the stock turbos where they get choked out up top. On big turbos you can turn up the wick.
