Need some wheel bolt help!
I just bought a set of Rotiform BUC's through my local VW specialty shop who is also a Rotiform dealer. The BUC's are Anthracite so he suggested using the stock bolts and caps instead of buying aftermarket. Once we got a wheel mounted up he told me we can't use the stock bolts or caps because the lock key won't clear the rim, nor will the caps.
Rotiform recommends using ball type lugs. Looking for aftermarket recommendations.
TIA
https://forums.vwvortex.com/newreply.php?do=newreply&p=114224991
GTI Jake
Charlotte, NC
I switched to studs and nuts.
As bad as ECS can be on some things they have held up great for over 60k miles so far on my car so they get my vote here
