need help! Coolant found in head mk7 gti 2018
Daser Drives
Bahrain
VW Golf GTI 2018
I have GTI 2018 mk7.5 US spec with filter custom downpipe and jb4 map6 by george.. and recently i started loosing coolant quickly and couldn't find the leak anywhere in engine bay..
So went to the workshop and they found water leaking into the heads over pistons specially 1 and 4 cylinder but the car ran totaly fine and never overheated neither any smoke..
Can someone guide me through this and explain me what happened exactly btw the car is still in workshop and being worked on currently.
swcrow
7.5 GTI
^this. head gasket is easiest and most likely answer
AceHammer
NY USA
2015 A3
Clear the codes, pull the battery then do a drive cycle once the JB4 is off.
No clue if this help clear out anything tbh but I've heard this repeated a few times from local VW people.
Also remove any performance-type shit from that car, ie stickers if you have em lol. Even better is if you have your mom take it in
Daser Drives
Bahrain
VW Golf GTI 2018
Actually am staying in Middle east and car is imported from USA so no warranty jst have to fix it in local workshop who are specialist in VW..
Yeah alot of water coming put of exhaust though.. but what do u think about reason of it happening? is it the jb4 map6 hitting 26psi? or something else?
You're probably only seeing water come out of the exhaust when the engine is cold. It would burn off if the engine was up to temperature. If you had that much water running into cylinder 1 and 4 it wouldn't run fine.
Daser Drives
Bahrain
VW Golf GTI 2018
just now got a call from workshop and they informed me it happened due to waterpump nothing related with headgasket they checkd it and its totally fine now..
yes Really weird but i was definitely expecting headgasket... now the car doesn't loose coolant at all and runs fine!
But disappointing because i already replaced the waterpump twice and am at just 26K kms.
It was covered under warranty wasn't it?
Daser Drives
Bahrain
VW Golf GTI 2018
nah man i dont have warranty.. the car is salvaged title imported from US to middle east.. i fixed it in local garage who are specialist in VW with new waterpump+labour costed me around 500 dollars with new coolant.
