Hey guys. I'm in need of a little advise. I have done a good bit of research on both of these topics using the search feature but need to clear up a few things. My 2010 GTI has 125,000 miles on it with the old style tensioner and block 93 is reading is reading 4.55 during idle and will go up to 5.2 if I give it a little throttle (yes I know it's a ticking time bomb). So I'm planning on having a full timing service done on it. I will be using a small indy shop who has done several of them before and he quoted my $375 for labor which I thought was very good. I can buy my own parts and am looking at this kit https://www.ecstuning.com/b-assembled-by-ecs-parts/ultimate-timing-chain-kit/06h198004kt/ Does anyone have experience with that kit? Are there any parts that it doesn't come with that I will need? I have heard some say that you need to replace the timing cover while others say they reuse it without issues. What say you all?
The other thing I will be having done is the rear main seal replaced (it's leaking). On other threads I have seen this https://xlr8performance.com/i-37265-vw-audi-billet-rear-main-seal-for-tsi-engine.html recommended several times instead of using the oem replacement. I noticed that shopdap stopped selling it because of leaking issues due to installation problems. So I'm not sure which route I should go. Thoughts? Are there any other parts I need to purchase besides the seal and bolts (basically what the kits come with)?
One last thing. With having both services done is there anything else I should have replaced as preventive maintenance? I have already done plugs, coils, all filters, and a dsg service. Anything I should mention to the mechanic to look out for while these areas of the car are apart?
Sorry for the long post I just want to make sure everything is done right the first time. Thanks in advance for any advice!
