Funnily enough I did this a while back but abandoned it. The hinge area is particularly tough with FDM printers as there is a lot of transverse load when you're pressing the paddle. Furthermore printing it all in one piece means the Z axis is weak (hinge wise). I separated the hinge and ended up gluing the knuckle back in with acetone.
Thank you for the insight! I was also thinking about the hinge points, mainly the lower one where the hole is larger. The revision I prototyped today has a slightly altered design for both hinge points so there's more material surrounding the hole, hopefully making it slightly stronger.
At the same time, the basic mechanism I want to try to incorporate to add a more tactile feel may help the rigidity of it all and relieve some stress, or potentially make it worse, I'm not sure yet.
Also, material is going to make a difference in the end as well, along with the points you've brought up. Right now I'm only using PLA for the sake of making test models, but I'm shooting to make the final product work with PETG or potentially a carbon fiber-infused PLA (though I think that might be too brittle for this application)
Speaking of today's design by the way:
(sound on so you can hear the "clicks")
We have a working base!
