Well, things can't ever go smoothly, eh?
As you can see above, there seems to be an issue with the new trans. At this point I have about 50 miles on the new setup, and it drives incredibly!
The outer seal between the transmission casing and the right hand axle cup ripped clean in half, and is now puking transmission fluid all over the nice new subframe and everything else under the car.
I replaced the seal on Monday with factory part #02Q-409-189-A . All seemed good on the initial test drive, but this seal too appears to have begun leaking.
Is there a different part number for the outer seal on a non-pp transmission? I can't imagine that VW would use a different size, but what do I know?
The leak was small enough with the replacement seal that I was able to limp the car to alignment, and it should be finished up this afternoon.
I'm finally getting close to having this thing sorted, just have to fix this seal and tie up a few loose ends!
