Good day all. This thread is to document the process of finding and fixing the noise coming from my engine when running. I will update it until the problem is solved.
For the past month or two, I have noticed a distinct sound coming from the engine. It started as an occasional squeak that would speed up and slow down with RPMs, and evolved into a constant metallic squealing/grinding noise that gets so loud you can hear it over my full exhaust system. At first I thought it was the alternator bearing, as it sounded like it was coming from there. I took off the belt and gave it a spin, and while it did have an occasional small squeak, it wasnt until I turned the AC compressor that I believe i found the cause of the noise.
This video tries to catch how the compressor sounds when I spin it:
Im pretty sure this is supposed to be silent when I spin it, so now starts the journy of learning how to replace and AC compressor myself. I contacted my mechanic to ask for some advice, as the AC still blows cold and I dont want to have to replace the entire system if I can help it. He said if the AC still blows cold, the failure is most likely the bearing and this wouldnt contaminate the system. The next step is to order a new compressor and take off the current one to see if theres any metal shavings in the lines. If so, this job is about to get a lot more involved and expensive.
Currently I am looking to buy a new compressor, options on RockAuto range from a $200 UAC compressor, all the way up to buying a brand new Denso unit for $330. Obviously the Denso is the best choice for longetivity, so this is most likely the route I will be taking. Straight from Denso.com its $374 plus tax and all that, so I hope partgeeks is reliable.
In order for this job to go well, I need to remove the compressor and flush the system. I plan to use this flush bottle kit and a solvent such as laquer thinner or an AC flush to clear it all out. Because the system will be flushed I also will need to replace the dryer/accumulator. They are pretty cheap, so its alright.
The part that has me stumped is the expansion valve. It has been recommended that I change it, however I have no clue where the hell it is in this car. From the online parts diagrams it seems to be inside the dash near the firewall. If this is the case, Im just gonna leave it and pray it all works out. If anyone can shine some more light on this it would be much appreciated.
Thread will be updated over the coming weeks/months as I sort this issue out.
