Multiple Errors - including airbag, autohold and ACC
jonmk7
Se15
Golf Mk7 1.4 tsi
Hi guys,
My mk7 has recently developed a load of issues and our local garage aren't able to help and the main dealership they referred me to can't look at it until next month. I'm obviously worried about the airbag. I've tried replacing the battery but it hasn't fixed the issues.
Any suggestions would be very much appreciated.
Cheers
Jon
OBDeleven vehicle history log
Date: 2022-01-06 20:55
VIN: WVWZZZAUZEW009773
Car: Volkswagen Golf
Year: 2014
Body type: 5-dr hatchback
Engine: CXSA 90 kW (122 HP) 1.4 l
Mileage: 138129 KM
Fault
Control unit: 01 Engine
Active faults: 0
Inactive faults: 1
System description: 1.4l R4 TSI
Software number: 04E906016DE
Software version: 5672
Hardware number: 04E907309A
Hardware version: H08
ODX name: EV_ECM14TFS01104E906016DE
ODX version: 002002
Faults:
U015100 - Lost Communication With Restraints Control Module
static
Mileage: 138129 km
Date: 2022-01-06 20:19
Fault
Control unit: 03 Brakes
Active faults: 0
Inactive faults: 6
System description: ESC
Software number: 5Q0907379CK
Software version: 0472
Hardware number: 5Q0907379G
Hardware version: H31
Serial number: 612530000009CC
ODX name: EV_Brake1UDSContiMK100IPB
ODX version: 033001
Faults:
C10CE29 - -AUTO HOLD- Button Implausible signal
Intermittent
U112100 - Databus missing message
static
static
static
C100C01 - Electro-mechanical parking brake button Electrical error
Intermittent
U112300 - Databus error value received
static
Mileage: 138129 km
Fault
Control unit: 08 Air Conditioning
Active faults: 0
Inactive faults: 1
System description: AC Manuell
Software number: 5G0907426M
Software version: 0705
Hardware number: 5G0907426M
Hardware version: H01
ODX name: EV_ACManueBHBVW37X
ODX version: 003019
Faults:
static
Mileage: 138129 km
Fault
Control unit: 09 Central Electrics
Active faults: 0
Inactive faults: 3
System description: BCM MQBAB M
Software number: 5Q0937084S
Software version: 0112
Hardware number: 5Q0937084S
Hardware version: H14
Serial number: 00011313001752
ODX name: EV_BCMCONTI
ODX version: 011001
Faults:
B12CA01 - License plate lamp Electrical error
Intermittent
static
static
Mileage: 138129 km
Date: 2022-01-06 20:20
Fault
Control unit: 13 Adaptive Cruise Control
Active faults: 0
Inactive faults: 3
System description: ACC Bosch MQB
Software number: 5Q0907572A
Software version: 0141
Hardware number: 5Q0907572 A
Hardware version: H03
Serial number: 18051376510370
ODX name: EV_ACCMRRBoschVW372
ODX version: 001013
Faults:
Intermittent
static
B10E7F0 - Cruise Control Front Distance Range Sensor separated
static
Mileage: 138129 km
Fault
Control unit: 16 Steering Column
Active faults: 0
Inactive faults: 0
System description: Lenks. Modul
Software number: 5Q0953507AG
Software version: 0070
Hardware number: 5Q0953549A
Hardware version: 007
Serial number: 18051308490017
ODX name: EV_SMLSKLOMQB
ODX version: 009001
Faults:
No trouble codes found
Mileage: 138129 km
Fault
Control unit: 17 Dashboard
Active faults: 0
Inactive faults: 1
System description: KOMBI
Software number: 5G0920961
Software version: 2210
Hardware number: 5G0920961
Hardware version: 252
ODX name: EV_DashBoardVDDMQBAB
ODX version: 008031
Faults:
static
Mileage: 138129 km
Fault
Control unit: 19 Gateway
Active faults: 0
Inactive faults: 1
System description: GW MQB High
Software number: 5Q0907530M
Software version: 1144
Hardware number: 5Q0907530F
Hardware version: 125
Serial number: 0000592643
ODX name: EV_GatewLear
ODX version: 009013
Faults:
- Unknown
static
Mileage: 138129 km
Date: 2022-01-06 20:21
Fault
Control unit: 42 Driver Door
Active faults: 0
Inactive faults: 1
System description: TSG FS
Software number: 5Q0959593A
Software version: 0006
Hardware number: 5Q0959593
Hardware version: 012
Serial number: 04051302090795
ODX name: EV_DCUDriveSideEWMAXKLO
ODX version: 006003
Faults:
- Unknown
static
Mileage: 138129 km
Fault
Control unit: 44 Steering Assistance
Active faults: 0
Inactive faults: 0
System description: EPS_MQB_ZFLS
Software number: 5Q0909144L
Software version: 1021
Hardware number: 5Q0909144L
Hardware version: 119
ODX name: EV_SteerAssisMQB
ODX version: 008022
Faults:
Mileage: 138129 km
Fault
Control unit: 52 Passenger Door
Active faults: 0
Inactive faults: 1
System description: TSG BFS
Software number: 5Q0959592A
Hardware number: 5Q0959592
Serial number: 02051302091217
ODX name: EV_DCUPasseSideEWMAXKLO
ODX version: 006003
Faults:
- Unknown
static
Mileage: 138129 km
Fault
Control unit: 5F Multimedia
Active faults: 0
Inactive faults: 1
System description: MU-S-D-ER
Software number: 5G0035820A
Software version: 0421
Hardware number: 5G0035820A
Hardware version: 040
Serial number: V5C02005131337
ODX name: EV_MUStd4CPASE
ODX version: 002039
Faults:
static
Mileage: 138129 km
jonmk7
Se15
Golf Mk7 1.4 tsi
Looks like the battery terminals may have been installed backwards at some point. Possibly?
It's certainly not something i've done. We've had the car for over 2 years and had no real trouble and the issue just popped up one day in the middle of a long drive. Could I ask why you think it could be a battery installed backwards? Is there any possible solution that I might be able to try?
Appreciate the help.
SouthFL_Mk7.5
South Florida
2019 GTI S
Not that the battery is currently installed backwards, as the car wouldn’t be able to run if that were the case….. but maybe it was attempted to be installed backwards at a certain point in time… as this would blow fuses, trigger many sensors, throw codes and render certain electronics incapable (like electronic power steering) due to blown fuses immediately thereafter the terminals being installed incorrectly.
I don’t think this is the problem with your car now, as you’ve described it happening in the middle of a long drive.
Harryv15
Florida
2017 Mk7 GTI S
Hi guys,
Cheers
Jon
Year: 2014
Mileage: 138129 KM
Fault
Active faults: 0
Inactive faults: 1
ODX version: 002002
Faults:
static
Mileage: 138129 km
Fault
Active faults: 0
Inactive faults: 6
ODX version: 033001
Faults:
Intermittent
static
static
static
Intermittent
static
Mileage: 138129 km
Fault
Active faults: 0
Inactive faults: 1
ODX version: 003019
Faults:
static
Mileage: 138129 km
Fault
Active faults: 0
Inactive faults: 3
ODX version: 011001
Faults:
Intermittent
static
static
Mileage: 138129 km
Fault
Active faults: 0
Inactive faults: 3
ODX version: 001013
Faults:
Intermittent
static
static
Mileage: 138129 km
Fault
Active faults: 0
Inactive faults: 0
ODX version: 009001
Faults:
Mileage: 138129 km
Fault
Active faults: 0
Inactive faults: 1
ODX version: 008031
Faults:
static
Mileage: 138129 km
Fault
Active faults: 0
Inactive faults: 1
ODX version: 009013
Faults:
- Unknown
static
Mileage: 138129 km
Fault
Active faults: 0
Inactive faults: 1
ODX version: 006003
Faults:
- Unknown
static
Mileage: 138129 km
Fault
Active faults: 0
Inactive faults: 0
ODX version: 008022
Faults:
Mileage: 138129 km
Fault
Active faults: 0
Inactive faults: 1
ODX version: 006003
Faults:
- Unknown
static
Mileage: 138129 km
Fault
Active faults: 0
Inactive faults: 1
ODX version: 002039
Faults:
static
Mileage: 138129 km
Did you ever figured it out what the fix was? I am having exactly the same codes and issues. Tried replacing the battery and no fix. I’m really looking forward to hearing from you fix!
