Moog Endlinks Grease
hotbascosauce
Seattle, WA
19 GTI SE DSG W/DCC
I have Moog endlinks and Hotchkis 25mm RSB which also has a zerk fitting on the brackets. I've been running this combo for about 2000miles. I just started to experience really bad squeek in the back of my car when the road is even the slightest bit uneven.
I bought a grease gun with an assortment of fittings, but what kind of grease am I supposed to use?
tmw2442
Mk7 R
Did you grease them during the install?
OldVWFan
NW Arkansas
17 GTI Sport
MOOG says to use premium heavy duty lithium or synthetic grease. Superlube synthetic grease in 14 oz. Tubes is what I use.
pseudorealityx
Decatur, GA
2017 GTI SE
Double check the bolts to the swaybar brackets. I had one loosen up a little and it gave me a squeak.
hotbascosauce
Seattle, WA
19 GTI SE DSG W/DCC
You are correct. My driver side sway bar bracket had gotten itself loose and actually bent the bolt.
I ended up buying some Valvoline synthetic grease because the Autozone near my house didn’t have lithium. Added some more grease to the end links and the sway bar bracket and the ride is very quiet now.
