Jovian
- Denver, CO
- 2016 VW GTI
Cloudyvale?
Past two days it sure was, nice and sunny currently
Cloudyvale?
Flow chart for mods:
Like what the rear swaybar did? Good! Leave the front alone, or you’ll gain your understeer back.
I'll be the centrist here- you're both right. Reducing front end roll increases front end grip and therefore limits understeer. But the relationship between the front and the back also matters. If you can stiffen BOTH ends, while shifting the bias to the rear, you're in the best situation.t would be true in a double wishbone setup, but on a mcstrut car where you gain positive camber as you compress the strut assembly, reducing front end roll increases front end grip and therefore limits understeer.
This should be a sticky and there should be a Thread called mods that are worth the money.
While I'll agree to most of the statements in this thread, this one is wrong. It would be true in a double wishbone setup, but on a mcstrut car where you gain positive camber as you compress the strut assembly, reducing front end roll increases front end grip and therefore limits understeer.
Don't believe me? Source
Do you get lift-throttle oversteer? Or is it well balanced with just the Neuspeed rear?I have 27 rear so 24/27 .88~ front bias lol
I think its decently balanced but I dont know what a lift-throttle oversteer is tbhDo you get lift-throttle oversteer? Or is it well balanced with just the Neuspeed rear?
Basically, it's when you going through a corner and let of the throttle, the tail starts to step out. In front wheel drive cars, it can help get you through the corner if it's controllable. In my old '91 MR2, it snapped so quickly that you sometimes couldn't recover (I had to learn to walk again after 3 months in a hospital bed).I think its decently balanced but I dont know what a lift-throttle oversteer is tbh
