I am 5’6” also, so I know the struggle. Lol A clutch stop makes a big difference. The different types have different feeling based on what they are made of. The ones that use rubber washers or spongy material as spacers have a softer feel, and the ones that thread into your retaining wall are more firm, and have a stiffer end point.So I’m only 5’6 and have to forward my seat to get good clutch engagement lol. How important is a clutch stop? Being short I think it can even help in that regard. And what are other clutch stop options that can fully return to stock when removing? Do you feel the clutch stop makes a huge upgrade in clutch feel?
The one I sell is firm and fully adjustable, but you have to drill your retaining wall (this is the same for the ECS clutch stop). So it is not a good option if you’re not sure if you will like it. Here is a link if you want to take a look at it: https://www.ebay.com/itm/234009640041?hash=item367c0fbc69:g:jyMAAOSw-VBgnzmH
If you want something to try out a clutch stop and see if you like it before committing to a fully adjustable one that requires drilling, I recommend this one because it uses metal washers so it has a firmer feel than the ones with rubber washers, but it’s still a little softer than the one I sell or ECS’. It also requires no drilling and is easily reversible just by pulling it out and putting the old plug back in: https://www.ebay.com/itm/331207149596?hash=item4d1d7c081c:g:zvwAAOxyF0pTgS2v
