Mk7R catch can
GolfRchris
Croydon
Golf R
Hi all, is there such a thing where you can actually buy a decent catch can set up without having to loose the washer bottle and buy relocation kits. Only asking as I like the bay looking stock and don't really want to get rid of the top portion. The likes of forge and racing line, bartek ect all make you looks the washer bottle.
many thanks.
scrllock
MI
Only off the shelf option I've found is the ECS can, though you want an aftermarket PCV as well if you're running high boost or tracking the car.
It's not too hard to fab up a bracket and make some -AN lines though, so you could use a much nicer can and your choice of mounting spot if you wanted to put in the effort. I plan on switching to a radium can eventually, the ECS can is kinda rough. And their lines are designed to go over the turbo, so re-routed like this with a reverse baffle works but it's not as clean as it could be.
