El_bigote_AJ
- Las Vegas
- 2019 GTI bunny
Part luck for sure - but also after fully removing the door assembly the catch on it also cracked some and flexed extra so it’s probably what helped allow the pressure to snap the one off. Also what’s not visible in the photos is the way my actuator broke is the reason I had room to easily get in between it. When inspecting them back to back the bad one pretty much seized up like 8mm out from the normally locked position and it doesn’t slide in or out when you try it.Nice! Still cant figure out how you managed to only snap one of the little ears in the actuator!
