daujin_mk7
- PA
- 2016 GTI DSG
I believe the two bolts that thread into the trans housing are 50nm + 90degrees. At least what Racingline provided.Not sure on that heim joint bolt - but Those are the incorrect specs for the 2 bolts that thread into the trans housing
You are going to snap the bolt or tear the threads if you do that since it’s not a strong steel material you are bolting to its 37ftb +90 degrees for those bolts if they are stretch. If they are not you really shouldn’t go much past 40
Edit: not sure if we are talking about the same bolts.
