Diggs24
- de plains! de plains!
- 2015 GTI
You can't cheat physics. Decide what's most important and buy the turbo that fits that need.
You will always want a new flywheel with these clutches … why not go a little better and get the RSR Hybrid? It still uses the stock DMFW
I felt the same way at first but changing the gear oil helped tremendouslyI hear you- my buddy went SMF on his GLI and regrets it deeply. It’s noisy too. I’m in the same boat- RSR hybrid is rated up to 550 though
I know EQT is more aggressive than APR and at stage 2… was it clutch slipHi guys, I got my south bend stage 3 daily more then a month ago and put down about 1200 km half city and half highway driving. I decided to try a full throttle pull today and the clutch slipped out and bounced a little (about 500 rpm or soo) before finally grabbing. This happens mostly in 3rd at 3000 rpm when I go full throttle. Is this normal behaviour and should I settle for a higher rpm before going wot?
Tune is eqt stage 2 and traction control is fully off.
Definitely clutch slip, I assumed stg3 daily would have been more then enough since the is38 guys also run itI know EQT is more aggressive than APR and at stage 2… was it clutch slip
Or tire spin?
by the sound of it its possible it's just the cobb traction control at workHi guys, I got my south bend stage 3 daily more then a month ago and put down about 1200 km half city and half highway driving. I decided to try a full throttle pull today and the clutch slipped out and bounced a little (about 500 rpm or soo) before finally grabbing. This happens mostly in 3rd at 3000 rpm when I go full throttle. Is this normal behaviour and should I settle for a higher rpm before going wot?
Through obd11 there is a option to completely disable traction control, but I did smell the clutch after so it basically narrowed it down to that for meby the sound of it its possible it's just the cobb traction control at work
is the gear indicator in the MFD disappearing when it happens? if it is then confirmed clutch slip. otherwise it's your tires breaking loose
stage 2 shouldn't be doing that to your brand new clutch unless there's some other issue at work.Through obd11 there is a option to completely disable traction control, but I did smell the clutch after so it basically narrowed it down to that for me
