+1 for the AAwireless unit. I've had it for a while now and it works great, no issues with bumps or disconnects, ever.
Setup was easy and it connects in seconds every time. The manufacturer has pushed a couple OTA updates since I've had it, and I appreciate how simple that process is as well.
If there's any con, it's that the phone battery drain is a little high when connected. But I have a phone charger in the center console outlet if needed for longer drives.
I installed the AAwireless unit yesterday and it is almost unusable. I've gotten it to connect a total of three times. Once I shut the car off and restart, it never reconnects. Blinking green lights. I've run through the troubleshooter at least a dozen times, which is how I got it to connect those three times. Beyond frustrating. I'm not sure how this thing is supposed to work, so maybe you guys can help me figure it out.
Should my phone be BT paired to my head unit (MIB 2.5, 2018+) when using this unit? Mine is.
Should my phone be BT paired to the AAwireless unit? Mine is.
Should my phone be connected to the AAwireless unit via wifi? If I try and connect to the AAwireless AP, it prompts me for a password, which I don't have. Is this normal? Do you use 2.4GHz or 5GHz?
Any ideas about what I should try next?
