cb1111
Newbie
Virginia, USA
Can you disable the auto parking brake "feature" that happens when you open the door while the car is moving? Sometimes I like to open my driver side door a little as I back into spaces and the car immediately stops.
After Anton Yelchin was crushed by his Jeep in 2016, manufacturers started added these interlocks.
Quite simply, the car shouldn't be moving with the door open. I've seen far too many accidents, where the door got damaged because the driver forgot how far it was open.
Doesn't your car have a backup camera?
Subliminal
Vegas
Slow FWD VW Hatch
So the car takes the trans out of rev/drive and turns on the parking brake?
LOL better hope that sensor never faults while you're driving
or what if you do that thing when the door isn't fully closed so you open it while you're rolling
i assume it only happens under ~8 mphs, so try parking faster? lmao
videoman
UK
every one of my golf 7 switches had gone bad. I opened 3 single doors one and every one had deposits on them, cleaning one as u see re pic, took off the copper track it was that bad. But the reason for this post, i have a stubborn front passenger window, re not auto up and down. So i replaced the master drivers 4 switch unit. all worked great, or so i thought. Seems totally at random on each of my journeys the window auto works "if it wants to" , i've tried resetting etc, still doenst work, then next time i get in the car, even if its after going into supermarket or the next day, the auto bit works. any ideas?
berserker6
South Jersey
2018 Golf R
That corrosion is excessive. Any chance this was a flood car? Or is water finding away past the door seals?
Acky771
Uk
Mk7.5 golf 1.4tsi
Hi all, have a question…
I have a 1.4tsi golf mk7.5 I’m looking to change the diffuser on the back to a gti one.
Can I straight swap the diffuser for the gti on or do I need to get a whole new gti bumper?
I cant seem to find a definitive anwser anywhere
Thanks I’m advance
Acadia18
2019 Golf R
the
Alabama
GTI
I can hear the engine shudder when putting the car in neutral and letting off the clutch at 40mph. Normal?
