JTM88
Broken Arrow, OK
2016 GTI
So I've been burning some oil recently, and I think it may be a bad PCV.
I've read on a few threads that the test is to remove the oil cap with the engine running.
When I do this I notice several things
- The engines idle increases a little, but otherwise runs fine
- There is a strong suction on the oil cap
- There is also a film of oil around the cap
Does this sound like a bad PCV?
FooDogg
Right on the Left Coast
2017 Alltrack S 6MT
JTM88
Broken Arrow, OK
2016 GTI
FooDogg
2017 Alltrack S 6MT
Let us know how it goes.
But if you dont mind my saying, give yourself a few days for more knowledgeable people here to give advice, too. I am not a mech, just a layman who reads a lot.
As one wise man here said, "dont just swap in parts until you have diagnosed the problem" ~Jim Lloyd, RIP
  • Like
Reactions: krs
manu97
Chicago
MK7 R
Not sure if this is stupid or not - what hardware should I be replacing/planning to replace when replacing a turbo?
manu97
Chicago
MK7 R
Look up any of the IS20/IS30 turbo install kits. turbo/downpipe gaskets, exhaust stud/nuts, and various o-rings.
That's such an obvious solution, I'm a little embarrassed I didn't think of it. Thank you!
Odinpig
Ohio
Mk7 GTI, Mk6 2.5
This was rattling around at large in my hood since I got the car. I finally fished it out the other day with a magnet. Anything to worry about or just a random fuckup at the factory?
swcrow
7.5 GTI
pretty sure that's the one that holds the motor together. part out.
It’s definitely engine bay screw…. Time to look for holes
wasbaggedonce
PA
2020 GLI Autobahn
Can you disable the auto parking brake "feature" that happens when you open the door while the car is moving? Sometimes I like to open my driver side door a little as I back into spaces and the car immediately stops.
krs
Las Vegas, NV
MKVIIS R
I used to do that in the 90’s before I learned how to drive.
Can’t answer your question though. Good luck. 🙂
wasbaggedonce
PA
2020 GLI Autobahn
The way my garage is, I need a good lower view on both the left and right. However, only the right mirror dips on reverse. Don’t feel like manually dipping the left and bringing it back up every time I back into my garage.
