JTM88
Broken Arrow, OK
2016 GTI
Which part are you having trouble with? The ground stud, the clip, or pulling the coil itself?
Holding backup on the ground stud to remove the ground nut.
El_bigote_AJ
Las Vegas
2019 GTI bunny
JTM88
Broken Arrow, OK
2016 GTI
Have a deep socket? Tends to be the easiest way to get the ground stud out.
I think you miss understand, I need a recommendation for a thin wrench to hold the stud so I can remove the grounding nut that is on top.
bobloblawGTI
DC
19 GTI SE 6MT
Anyone know how to fix a windshield that won't de-fog? Got the front defroster on, AC, no recirc, and still it never clears. Goes away briefly with wipers and then comes back. I assume it's something on the outside, any tips on what'll clear it?
manu97
Chicago
MK7 R
If it's on the outside - the front defroster may be hurting rather than helping
JC_451
NJ, one of the nice parts.
2017 GTI Sport
You gotta blast the heat.
Super uncomfortable, but if you can't take the moisture out of the air you can at least equalize the inside and outside temperature which will stop the condensation.
sterkrazzy
United States
Turbo. Blue.
Do you use rain-x? I had terrible fogging on my mk6 after using it. It was only a problem at night with really wet/humid conditions. 0 problems since switching to aquapel.
akimmel
Ipswich, MA
2015 GTI AB 6MT
Can't remember how I counter-held mine at home, but at work I'd be looking for the shittiest 10mm in the drawer and a grinder with a 36 grit disk. Or my knipex 125 pliers wrench, they have some pretty gdang thin jaws.
JTM88
Broken Arrow, OK
2016 GTI
