"does is want moar hrsepwer how?"Asking that
Yes...but sometimes no...but also maybe"does is want moar hrsepwer how?"
Not directly an answer to your question, but your biggest braking gains are going to be in more aggressive pads and better fluid.After much googling I've come to ask: Has anyone attempted rear brake upgrades on Golfs with a rear beam? I've seen it mentioned but never confirmed.
Paging @CuzoeAfter much googling I've come to ask: Has anyone attempted rear brake upgrades on Golfs with a rear beam? I've seen it mentioned but never confirmed.
Someone called, haha. @bmxdarcy I am running GTI PP brakes on the rear of my Golf TDi. The e-brake lines come in from other side (top or bottom, I forget which) so the e-brake cable routing is shitty, but has not caused any issues since install.Paging @Cuzoe
YesSo stupid COBB TC question. Do I have to turn off ESC for it to work correctly?
I don't have front assist FYI.
Thank you. I use only top tier, choose mid grade when towing heavy,One thing is for sure: you should not be running 87 octane while towing. And in hot weather? <Dark Helmet voice> "What's with you, man?!"
Which part are you having trouble with? The ground stud, the clip, or pulling the coil itself?Is there a specific thin wrench anyone can recommend for getting the ignition coils offf with? I had always been able to get away not using one until today.
