GenX Retread
Canada
2021 GTI Autobahn
The springs are taking care of the lowering part, such as it is.
I've never used plasti-dip, is there anything special about applying it? I wonder if regular ol' Krylon will flake off due to the springs flexing?
kyLman
Grand Rapids, Michigan
2015 Golf
I would guess the flex will make plastidip crack very soon. Powder coat might work. Hydro dip maybe? Can you strip the OE paint off the springs? Then most should stick
KyACRASH
Fort Walton Beach, FL
2015 GTI 6MT, 04 R32
H&R springs have a sort of rubber/textured coating. I'd try regular spraypaint but don't expect it to work very well. I'm all about aesthetics, but you really can't ever see the springs unless your wheels are off.
wasbaggedonce
PA
2020 GLI Autobahn
I'll be completely honest, this is the first time ever in my life that I've had dedicated snow/winter tires (studless), and I'm sliding around all over the place. I'm guessing they're just not good on dry roads. I figured it was time to put them on because it was snowing and freezing and not going above 40ish most days. I guess I'll just have to adjust my driving style. I spun in fourth trying to pass a truck on the highway..
JohnnyGTD
Wales
2014 Golf GTD
Hello all, another stupid question if I may. What is supposed to go here?
OldVWFan
NW Arkansas
17 GTI Sport
Mine has a small rubber bumper.
swcrow
Virginia
7.5 GTI
Passenger side window all of a sudden lost memory for all up all down… How did that happen? How do I reprogram it?
swcrow
Virginia
7.5 GTI
Strange, the window was rolled all the way up already when you tried?
I retried it. Evidently it was a millimeter for being all the way up. When I insured it was all the way up and followed your instructions. Boom it worked. Thanks!
shovelhd
Western MA
Which tires?
Size?
What size wheels?
Pressure?
How many miles on them?
Suspension mods?
If they're brand spanking new the mold release needs to wear off, so drive it hard for a bit. Pressure depends on the answers but if you have soft sidewall snows, you can make up for a bit of the slop by running 2-3psi higher than your summers. It's a balance between handling and ride quality.
KyACRASH
Acadia18
2019 Golf R
