It was the channels for the outer lights I couldn't figure out. Everything I found online was for EU models and didn't apply to my carYes. Under the light channel you want as DRLs, probably directly under the "Standlicht" function or another one that has an appropriate light level, add the "Tagfahrlight" function.
I did this successfully. Hopefully that points you in the right direction, but let me know if you need me to look up details from my own coding.
Looks like you have a prefacelift, so the outer lights should be channels 20 and 21. Here's an example for the left side:It was the channels for the outer lights I couldn't figure out. Everything I found online was for EU models and didn't apply to my car
What’s the general consensus on best summer daily driver tires? Back in the MK6 Vortex days everyone said Falken.
It’s because we are awesome, bro
I like this but.....if the socket is on an extension and goes past the rubber it may become detached under the rubber when you try to pull it out. I would consider gluing/weld the socket securely to the extension (epoxy) the sacrifice of a socket/extension compared to trying to extract the socket would be worth it.Someone did you wrong at engine assembly. Rub a bit of oil on the socket and push it through.
You start the car, put it in drive, flip it over to manual mode, then flip it back to drive, then push the gas to drive off?
No lol, props to me for stroking out when I typed that. Minus the extra put it into drive.You start the car, put it in drive, flip it over to manual mode, then flip it back to drive, then push the gas to drive off?
Yeah It's obviously not a huge deal, just a curious little thing that it only happens when starting in M and never happens anywhere else.So, manual mode 1-2 shift is causing you grief. hmmm, no such issue here. I'd say keep the shift sooner, don't need to really use much of 1st anyways how this car is geared.
sweet, cant wait to try this out this weekend. thank you!Looks like you have a prefacelift, so the outer lights should be channels 20 and 21. Here's an example for the left side:
The right side should be essentially the same, just with "21" everywhere there's a "20" above.
- Go to Leuchte 20BR LA71
- Scroll down to Lichtfunktion E20, which should be "Standlicht allgemein (Schlusslicht...)." Leave this line alone.
- Change the next line, Lichtfunktion F20, from "not active" to "Tagfahrlicht."
- Save changes.
