cb1111
Newbie
- Virginia, USA
or "partially identical"....You mean exactly similar?
But to get this back on track, I get what doggy papa is saying and yes AFAIK, everything but the gearing is the same.
There’s a special one for the anti theft bolt. Inside is cut different. It’s completely round instead of hexed.Do the OEM wheel bolt caps work with OEM accessory anti-theft wheel bolts?
The r’s dsg cooler is external and on the front bumper while the Gti’s cooler is sort of right on the dsg no?or "partially identical"....
looks the same to me. (try to convince yourself it is...)I realize this is about as nitpicky as it gets, but for those who have done the power folding mirror retrofit: do your mirrors fold up at the same rate? My passenger mirror folks in quicker than the driver side does; is there some way to get them synchronized?
Video:
What? You’re tripping. They’re identical.I realize this is about as nitpicky as it gets, but for those who have done the power folding mirror retrofit: do your mirrors fold up at the same rate? My passenger mirror folks in quicker than the driver side does; is there some way to get them synchronized?
Video:
Hah my dad said the same thing, so y'all are right... and thanks! I managed to break one of the clips in my passenger mirror cap but other than that things went really smoothly. OBD11 coded everything beautifully and the fishing line trick with the cable routing made things a breeze. Definitely recommended especially if you're a city street parker like me.What? You’re tripping. They’re identical.
I think you’re being too critical, respectfully speaking.
also. Came out dope!
I think you just cut out the rib part of the caps. cheap enuf online from ebay/amazon to experiment if neededDo the OEM wheel bolt caps work with OEM accessory anti-theft wheel bolts?
I can tell you they definitely do NOT fit aftermarket anti-theft wheel bolts. Turns out circles don't fit great inside hexagons.Do the OEM wheel bolt caps work with OEM accessory anti-theft wheel bolts?
How are you sure?Can I use my GTI while it has a bad coolant temperature sensor? It's reading high, but I'm sure it's cooling fine.
The OEM anti theft bolts should come with a cap specifically made to fit the locking bolt. Here they are side by side:Do the OEM wheel bolt caps work with OEM accessory anti-theft wheel bolts?
Car started pumping coolant and warning of high temps before I even started it (over a day had passed). Tried erasing the code to no avail.How are you sure?
I sure wouldn't drive it.Car started pumping coolant and warning of high temps before I even started it (over a day had passed). Tried erasing the code to no avail.
