Lth0ms0n
United Kingdom
2013 Golf GTD
Another stupid one.
How the f*ck does the aux heater come out past the past bar across the main dash frame when the glovebox is out?
Following Haynes manual for matrix removal, got past first pipe on the Matrix but need more wiggle room to remove lower pipe - can’t get aux heater out to allow more space to adjust it; matrix only needs to come forward at the top a few mm and the pipe will be better lined up to pop off!
The rope was instrumental in giving me the leverage to remove the top one 😅
Keehs360
Denver
Mk7.5
Stupid question
was talking to @StorableComa about this and he couldn’t answer. So I figured I’d ask here
the cooling system on the mk7 and 7.5. The radiator, pump and all ancillary things. Are they different than the ones in the golf wagon?
Stupid question
All I know is the thermostat housing leaks in the Golf just like the GTI. 😂
golfdave
Scotland (U.K.)
Mk7 Golf GT Estate
Stupid question
Nope....the GSW is only different after the rear axle......so for the same engine & same spec both hatch & estate will be the same front end..
golfdave
Scotland (U.K.)
Mk7 Golf GT Estate
So the GTI and golf wagon share the same radiator, fan, water pump etc?
No.......I'll repeat:- "for the same engine & same spec both hatch & estate will be the same front end".
The GTI engine was never fitted to the GSW.....the nearest is the 1.8lt which has some differences between it & the 2lt GTI...
Keehs360
Denver
Mk7.5
Oh ok gotcha. This makes sense now. Thank you.
vwGTILife
Please correct me if im wrong, but i was under the impression that in order to read ethanol content in the jb4 app I would need to purchase the Fuel It kit from BMS.
The reason I am inquiring is because the other day i filled up with E30 at the pump and in the app it read 30 for E85 content, and then yesterday i filled ip 11 gallons of 93 and in the jb4 app it read 7 for E content. Is this some kind of fluke/coincidence or what?
Thanks in advance
Keehs360
Denver
Mk7.5
The fuel u used probably wasn’t e10
vwGTILife
Hmm... not exactly sure what you mean. I still had about 2 gallons of e30 when i filled up and then it depends if the 93 i got had any ethanol in it or not. I guess my main question is weather or not the jb4 can detect ethanol content without the fuel it kit.
Keehs360
Denver
Mk7.5
Oh I dunno about that
what I tried to explain (poorly, sorry) was that if u have e30 and get to a 1/4 tank (for example) then fill with premium. You will dilute the ethanol content.
as far as the jb4 playing nicely with your content sensor, I dunno. Sorry
but the fact that you dipped under e10 tells me the fuel you used isn’t e10
vwGTILife
Ahh yes i see what you meant now. Thanks
