KessyStupid question
I can’t remember what was the name of the handle system. The one u touch to lock and put your hand in to unlock. Was it carr? Karr?
That’s what it was. Thanks!!!!Kessy
KeehsyKessy
LolKeehsy
If you didn’t mess with the setting on obd11 and it’s changed now then yeah with that display on better infotainment should have the “beep on lock” setting visible and adjustableThat’s what it was. Thanks!!!!
the gli won’t honk when u touch the notch on the kessey handle. Door will lock on the first touch. But on the second it won’t honk or do anything. It used to. I used to touch it twice, first time it’ll lock the doors and on the second you’d hear the honk. But for some reason it won’t anymore. I’m wondering if it’s something in the cars infotainment settings
Thnx I’ll give it a look in a secIf you didn’t mess with the setting on obd11 and it’s changed now then yeah with that display on better infotainment should have the “beep on lock” setting visible and adjustable
Yes. It operated similar to my GTII thought the "beep on second lock" was only via keyfob. Are you sure that touching the dimple a second time got it to chirp?
Yup. That was it. Thnx.If you didn’t mess with the setting on obd11 and it’s changed now then yeah with that display on better infotainment should have the “beep on lock” setting visible and adjustable
I’m not filling until my ethanol tester comes in tomorrow. I’m just asking once I know the ethanol level, should I try to empty the tank as much as I can to then fill up and mix or if mixing while my tank is 60ish% full of 91, go ahead and mix like that by using the ethanol calculator AFTER checking the ethanol levels. No way in hell was I gonna pump without the tester in my possession lolNo the AP doesn’t show content on the VW.
Either get a content sensor on the car or buy the 10 dollar testing kit and test the content at your pump before you fill it, then when you determine the ACTUAL content of your pumps e85 that day use the online calculator.
Till then... don’t just guess your ethanol levels, flash that tune, then blame tuner for a knock happy tune file.
I've read it's best to pump E85 then 91 or 93, I guess it mixes in the tank better. But I have done it the other way around with no issues (occasionally near the end of the tank the E level goes up a tick or two).I’m not filling until my ethanol tester comes in tomorrow. I’m just asking once I know the ethanol level, should I try to empty the tank as much as I can to then fill up and mix or if mixing while my tank is 60ish% full of 91, go ahead and mix like that by using the ethanol calculator AFTER checking the ethanol levels. No way in hell was I gonna pump without the tester in my possession lol
and the AP does show the fuel level. Not the ethanol level but the fuel the car currently has. I believe on the access port the gauge is called “fuel level input”. I haven’t married my AP yet until I have my tester ready so I can then marry it and install my E30 tune so I can’t confirm the name of the gauge but from the videos I’ve watched, I think if I remember correctly, that is what it’s called
unless it’s not for VW’s. Cause now that I remember, the videos I watched the guys were showing it on a Ford and a Subaru. So I might be incorrect in terms of the gauge being the AP for VW
Do you have obd11? You can enable a display on the dash mdi that will show something like gallons left or gallons to be full, (can’t recall what it is right now) but that could help also. And no you don’t have to wait till fully empty you just have the adjust the calculator setting for the amount of 91 you have so maybe 60% = 6-7 gallons. Then use that to know how much you can top off with.I’m not filling until my ethanol tester comes in tomorrow. I’m just asking once I know the ethanol level, should I try to empty the tank as much as I can to then fill up and mix or if mixing while my tank is 60ish% full of 91, go ahead and mix like that by using the ethanol calculator AFTER checking the ethanol levels. No way in hell was I gonna pump without the tester in my possession lol
