Ghost GTI
Cockpit
'19 GTI SE DSG
StorableComa
SoCal, USA
17 GSW S FWD
Yes, that's the hybrid mount that replaces the lower bushing with inserts for the upper bushing
The upper and lower inserts look like a taller stage 1 insert as it just fills the voids in the upper and lower bushings.
https://www.powerflexusa.com/shop/p...-front-lower-engine-mount-insert-large-a-2891
Edit: Make sure you order the correct type for your Dog bone style. They have a A and B model depending on which you have.
Ghost GTI
Cockpit
'19 GTI SE DSG
Got it. Should I go straight to that instead of the insert? Car only has 2k miles still.
StorableComa
SoCal, USA
17 GSW S FWD
Seeing as you've already replaced the lower bushing I'd say go for it. The inserts are a nice choice for those unsure about NVH as it's easy to remove and you don't have to cut out the lower Dogbone bushing - plus you can use the red diesel insert for softer still. If you've already modded it, I'd go full hybrid.
