How do I cancel the "inspection due" message in the MFD? It doesn't delete it when you do the same procedure to turn off the oil change due message.
someone asked a similar question (I think) recently. It was an IS38, not big turbo, but the consensus was, sure?So, has anyone tried a big turbo, stock intercooler location upgrade with no downpipe? I’m thinking this could pass state emissions on a stock tune, then switch back to a custom tune (EQT
Cheerssomeone asked a similar question (I think) recently. It was an IS38, not big turbo, but the consensus was, sure?
https://www.golfmk7.com/forums/index.php?threads/is38-tune-with-factory-downpipe.372168/
See if this helps. We don't have any info about your car specs to know which lights you have but this will probably cover itHi all, this certainly qualifies as a stupid question.
How do you take the dust covers off the back of the main headlight unit?
I know you're meant to turn it one way, but try as I might, (both directions) they will not budge.
I've got a AFS Bend lighting error on my 64 mk7. Reading up, most people say to change the bulbs. Being a "easy fix" I thought I'd try swapping the h7 bulbs but I'm stuck at the dust covers.
Any ideas?
This mostlyit is easier to make $ by including upgraded features in higher spec models. I used turning on factory alarm to justify my purchase of OBD11.
Welcome and newbies are expected to include pictures
Mud
