Diggs24
- de plains! de plains!
- 2015 GTI
Stand to side of car. 2 hands, left pulls, right pushes. I've debated some plumbers silicone in the threads before.....
Sounds like it. Mine was 3 years and 12k miles in when it tapped out. Started with slow windows with the engine off, then slow cranking, then dead....so the other day (cold in the teens) I had to redo my auto up windows. It MAY be cranking a bit slower.....early battery failure?
2 1/2 yrs
I never had this problem, but there are always solutions if you don't have the upper body strength.I used plumbers silicone on the threads and even though I didn't need to add coolant I unscrewed it after 2 months just to check how hard it was to still unscrew it and it made it much easier. It was actually silicone for swimming pool use but it's probably the same thing.
For the first time I was messing around with my fog lights yesterday. I usually put it in "auto", set it and forget it mode. So my dumb question is, why do people put the "Euro" headlight switch in so they can have their fogs on, when on the stock switch you can turn it to auto and pull the knob out to turn on the fogs? Why not just leave it like that, what am I missing?
Its so you can have just your fogs and DRL's on without the headlights. If you have it in auto and turn the fogs on your headlights will always be on even if its light outsidebecause they should have just bought an OBDeleven and activated it that way. OR.....they wanted to add a rear fog mod.
Depending on your state laws it may be illegal to drive with headlights off at dawn/dusk (not just foglights, actual projector headlights). Also people forget that if your wipers are on, your headlights must be on in many states.This. I don't like DRL's so I shut mine off. With the Euro switch I can have just fogs on in inclement weather during the day or at dusk when headlights aren't needed yet but some visibility to other vehicles might be useful.
That makes sense. I didn't realize fogs on meant headlights always onIts so you can have just your fogs and DRL's on without the headlights. If you have it in auto and turn the fogs on your headlights will always be on even if its light outside
curiosity...why don't you like them? You can't see them from inside car...not trying to break stonesThis. I don't like DRL's so I shut mine off. With the Euro switch I can have just fogs on in inclement weather during the day or at dusk when headlights aren't needed yet but some visibility to other vehicles might be useful.
