cb1111
Newbie
- Virginia, USA
Yep, thinking of it. VCDS is a bit out there at the moment for basically scans and preference changes so will probably get an OBDeleven to start. I checked it the other I've and for what it is If rather go with the one with a company a bit more invested, once they confirm the 2019 compatibility update.
Sent from my SM-G965U using Tapatalk
Are you suggesting that Obdeleven is more invested than Ross-Tech (VCDS)?
Let me clarify for those who don't understand the history.Must be a newbie.
The first reasonably available VAG software was from a company called ShadeTree software that ran on the Palm Pilot. When the Palm Pilot went away , ProDiag lost the customer base but it was still updated to 2015 or so.
Around 2000, Ross-Tech started selling VAG-COM. RT is a group of techs that designed this software to augment the VW systems in use at dealerships and to allow individual owners to check codes and make changes. VAG-COM morphed into VCDS somewhere mid/late 2000's and was a name change more than anything else.
In 2014 (ish) a Lithuanian group of coders put OBDeleven together. They are not techs and users rely heavily on the RossTech forums for (car) technical support because the coders can't help.
RossTech, in the US, is undoubtedly the leader, with OBDeleven being the poor relative that has a flaky business model and, I suspect, will go the way of Pro-Diag.
