stupid Question about alignment and front sway bar end links
So I did a dumb thing when I was doing an at home brake job. I had the bright idea of removing a sway bar end link in order to get access to the front caliper bolt when I had my car jacked up, realized a little too late I could just turn the wheel to access it but that is besides the point
anyway as I started to untorque this bolt circled in green (this is not my photo it's just one I found on google showing the bolt I touched) and when I realized how much weight it seemed to hold I figured I was about to do something really dumb so I tightened it back up with my torque wrench and all seemed to be fine but now my steering wheel seems to show a slight favoritism to right side
I needed an alignment anyway as I was due for one
is this something I should tell the people at the shop that I did or will they adjust these bolts on their own when doing an alignment to asses my steering wheel situation? do they touch these parts when doing a proper alignment?
obviously it seems that my issue was caused when I re tightened this bolt while the car was jacked up on the passenger front side of the car but I dont know how else I could access this bolt without the wheel removed or it up on a lift which I do not have or access to so I guess I f***ked myself a little here? car drives fine just the steering wheel a little off
