swcrow
7.5 frankenstein
@scrllock
Remind me....what is minimum thickness on the TTRS 370mm rotors....31mm? I can't remember...
EpicTech
Houston
MK7 GTI 6sp w/PP
Does a brake pad swap require a ABS calibration?
Munka01
Sydney, Australia
2017 Golf TSI 1.4
Does anyone know if the dog bone (specifically the black part in pic) is the same in all versions of the Golf? (TSI/GTI/R)
Munka01
Sydney, Australia
2017 Golf TSI 1.4
Also recently (yesterday) got 034 lower and upper dogbone mounts installed, while I was expecting some NVH, mine seems more pronounced than other reviews suggest, i get a big vibration when pulling away that resonates through cabin and also happen at points during WOT in 1/2/3. I noticed the lower mount is sitting slightly off center, does anyone know if it should be perfectly straight?
scrllock
MI
It is not. I have seen at least 3 different versions.
Using metal to add rigidity in a bushing will always do this. Avoid metal inserts or metal bearing'd arms if that vibration bothers you.
aegis
Ontario
MK7 GTI
Used FCP Euros lifetime warranty and returned a water pump. Now I have $300 in credit. Do they still warranty oil? Get me that fancy green stuff. Website says "One-time use items: Consumable items intended for single use are ineligible for warranty or LRG returns. Examples include additives, cleaners, shop supplies, etc." I assume motor oil is single use consumable....
Coincidentally, I just dropped off oil to ship back to them last night to see if the whole process was worth it. They accepted oil, oil filter, and drain plug on the RMA form so I sent it all back to see what I get in credit.
Following up with this, they offered full store credit for all of the returned items. 6L of oil, the used oil filter, and the used drain plug.
MonkeyMD
EpicTech
Houston
MK7 GTI 6sp w/PP
Two questions:
Anyone running the Revo engine & tranny mount upgrade kit?
my cf mirrors look shitty after sitting in the Texas sun. What are better options? Just get expensive ones from like Premium Duetsche Carbon or similar?
Munka01
Sydney, Australia
2017 Golf TSI 1.4
As noted in my post, its not that the vibration bothers me, its that mine appears more excessive than others suggest, so I am trying to determine if it is installed correctly.
