Pineapple
- Boston, MA
- 2017 Golf GTI S
Hope so ?^ Those LCA's work on MK7 ?
But (not to insult anyone's intelligence, but I'd rather it be said than left ambiguous) the hardware is TTY/stretch, thankfully it's cheap OR you can likely replace with non-stretch hardware if you use good stuff.No reason they shouldn't. I have LCAs from a 2021 8Y S3 on my car now.
@Pineapple no need to mess with ball joints unless they have play or torn boots.
Oh yeah, I was more hoping Pineapple would see it since he's the one who initially asked. Regardless though, I'll always specify to replace hardware because I'd rather someone hear it again than have an axle fall out (real story, happened to a friend of a friend when they reused mk3 axle bolts)I was responding to the LCAs fitting.
100% all bolts need replaced on these cars when removed. I have a list ready to go for a local dealer because I've had the subframe out and LCAs off at least half a dozen times in the last year or so ?
Geez. You could just go with grade 8 hardware and call it good with that amount of churn. Or go big baller and do all titanium hardware ?I was responding to the LCAs fitting.
When you say stuttering, what do you mean? Changing plugs makes it go away?
Probably because it doesn't register it as an event. All the sensors are sensing specific things, like knock. There's no sensor to determine how well a spark occurred. Nothing measures load at the two grounding points, either. So something is just eluding the sensors.Stuttering meaning I can feel some vibrations & a sought drop in rpm. Usually at idle. Very sporadic. Haven't changed plugs yet. But my question is more why they don't show up in live data
In my case, a lot of rougher idle (beyond the normalness of the factory "heartbeat" or whatever they termed the general rough idle from day 1), got significantly worse with a dogbone and then was subsequently resolved with new coils. Mine never came with the updated beru coils, which do a better job of resisting heat. Track miles on 100F days take their toll on coil packs for all cars.
Yours sounds way worse than what I was experiencing at idle, though. On track I would get misfires at 4-7k rpm under wot and those i could properly feel and they'd register. For me, the rough idle was not a "misfire", but felt more like poor combustion and not ill timed or lack of plug spark. There was no knock, nothing to register. Plugs would make it better for a few hundred miles then it would come back.
Might as well have said Netscapeaol.com. lmao
